Ha_Ku_Na
Mar 17, 2021Luminary
Alternative ways to troubleshoot instead of just downgrade FW in case of issues
We have here in the community are very "active" user who suggests for all kind of issues a firmware downgrade. But there are a lot of users using the latest FW (for RBK50 2.7.2.104) without any i...
Ha_Ku_Na
Mar 18, 2021Luminary
some facts:
- 1 thread, 8 answers, 4 from the same user (with no added value)
- there are at least 2 actual posts in other threads, where a factory reset helped
https://community.netgear.com/t5/Orbi/Orbi-DNS-and-DHCP-and-NTP-Broken/m-p/2071538/highlight/true#M116852
https://community.netgear.com/t5/Orbi/RBR50-2-7-2-104-firmware-Issues/m-p/2071667/highlight/true#M116882 - I have some minor mistakes in the opening posts and to clarify, I should add a final step
this part:
5. if step 3) does not help, proceed with the following steps
downgrade the firmware
6. if issues are still not fixed, reset the router and do the setup as described in step 3)
should be changed to:
5. if step 4) does not help, proceed with the following steps
7. if issue still exists, try to find help here in the community
As I cannot edit the initial post, I'm thinking about opening a new thread with the updated instructions.
And there I hope we get posts/answers which are related to the initial post.
- vajimMar 18, 2021Master
No one will consider your advice of any value as long as you continue to turn this into a food fight by posting such as
IMPORTANT ADVICE:
please ignore posts from user vajim.
He is just acting like a bad troll here in the forum.
Unfortunately the moderators are not taking any actions against that.act civil and you may get the results you desire
