dja2k's avatar
dja2k
Amazon Echo and Google Home are both delayed
Recently I have problems with Amazon and Google's home speakers.  They wake up but take long to respond, mostly throwing out the "something went wrong, try later".  The Orbi system is up and running, internet is working flawless in all other areas, ethernet and wifi.  I thought maybe something might be blocking their outbound connection, maybe the built in filtering of Bitdefender or something, I honestly don't know, but its driving me nuts.  Anyone else seeing this behavior lately?
1 Reply
  • FURRYe38's avatar
    Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
    https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
