stratified
Dec 27, 2018Follower
Amazon fire stick RBR40
We have an orbI80 that is not happy with an Amazon firestick. All other devices connect fine. Firestick says it is connected to the wifi but when we go to netflix we get an error message NW-2-5
Fir...
- Mar 03, 2019
Ok, I have resolved this. I reduced the MTU size from 1492 to 1464 and it now logs in fine. It also appears to have fixed another issue on my network whereby my wifes phone would not connect to the LinkedIn app for anyone searching for this combination! I found this here: https://community.netgear.com/t5/Orbi/RBKR50-MTU-Setting-Query-for-Netflix/td-p/1660878
Dec 27, 2018Guru - Experienced User
If you can get to netflix with other devices and not the Firestick, the probably maybe the Firestick.
You might see if you can reset the Firestick and set it up from scratch. Contact the Mfr of the Firestick for help and information regarding there procuct. Ask to see if there is any specific wifi settings needed on the Orbi for the Firestick.
Ensure there FW on the stick is up to date.
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
What WPA security modes are you using? Try Disabling WPA temporarily and test. Then try setting WPA2 and AES only.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
