stratified
Dec 27, 2018Follower
Amazon fire stick RBR40
We have an orbI80 that is not happy with an Amazon firestick. All other devices connect fine. Firestick says it is connected to the wifi but when we go to netflix we get an error message NW-2-5
Fir...
- Mar 03, 2019
Ok, I have resolved this. I reduced the MTU size from 1492 to 1464 and it now logs in fine. It also appears to have fixed another issue on my network whereby my wifes phone would not connect to the LinkedIn app for anyone searching for this combination! I found this here: https://community.netgear.com/t5/Orbi/RBKR50-MTU-Setting-Query-for-Netflix/td-p/1660878
ekhalil
Dec 27, 2018Master
Firmware version 2.2.1.210
Have tried changing DNS and channel but does not help.
Can access netflix from laptop using the orbi router so the problem is not with streaming - must be a problem with the router settings for the firestick??
Any suggestions??
The Netflix error code NW-2-5 indicates a network connectivity issue, which means that there is something preventing the device from connecting to Netflix.
Two areas to check in Orbi for this device:
- Do you have Parental Control enabled? Please check that the device is allowed the needed access in Circle or OpenDNS
- Access Control. Please check that the device is not in the access control block list.
stuartjsmith
Mar 02, 2019Guide
Did you ever resolve this? I ahve the exact same issue.
Firestick 4k
Netflix error NW-2-5
Orbi RBK53
All connectivity checks done in the Netflix app appear ok
Switch Firestick to personal hotspot on phone and no error
- FURRYe38Mar 02, 2019Guru - Experienced User
OP hasn't posted back his there initial post.
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
Firestick 4k
Orbi RBK53
- stuartjsmithMar 02, 2019GuideI have a netgear dn200 in bridge mode, and the orbi is running in router mode. Netflix works on every other device in the house, just not on the firestick 4K. The firestick 4K will work on my mobile network though when connected to the hotspot. I even got the shop the replace the firestick in case it was an issue with that one, but it didn’t help.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using?Try enableding Beamforming and MIMO.
