stratified
Dec 27, 2018Follower
Amazon fire stick RBR40
We have an orbI80 that is not happy with an Amazon firestick. All other devices connect fine. Firestick says it is connected to the wifi but when we go to netflix we get an error message NW-2-5
Fir...
- Mar 03, 2019
Ok, I have resolved this. I reduced the MTU size from 1492 to 1464 and it now logs in fine. It also appears to have fixed another issue on my network whereby my wifes phone would not connect to the LinkedIn app for anyone searching for this combination! I found this here: https://community.netgear.com/t5/Orbi/RBKR50-MTU-Setting-Query-for-Netflix/td-p/1660878
stuartjsmith
Mar 02, 2019Guide
I have a netgear dn200 in bridge mode, and the orbi is running in router mode. Netflix works on every other device in the house, just not on the firestick 4K. The firestick 4K will work on my mobile network though when connected to the hotspot. I even got the shop the replace the firestick in case it was an issue with that one, but it didn’t help.
Mar 02, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using?
Try enableding Beamforming and MIMO.
- stuartjsmithMar 02, 2019GuideI don’t think this is anything to do with satellite positioning. Everything else on the firestick works fine e.g. amazon prime video, plus I can plug in an old style fire stick with Netflix on and it works absolutely fine. It is specifically the combination of the new fire stick 4K, Netflix and the Orbi. I will experiment with the other setting you have mentioned thanks!
- stuartjsmithMar 03, 2019Guide
- gr8shoMar 03, 2019Virtuoso
Amazon was selling the Ethernet adapter for $10 recently and I picked up a few . An alternative if you can take advantage of it .
stuartjsmith did you see/follow FURRYe38 suggestion to make sure the Orbi is connected to a DMZ port?
