thedak
Jan 01, 2017Apprentice
Android Genie App and Orbi and Access Control
Hi, have the lastest ORBI firmward and the latest Android Genie App but the access control toggle seems to do nothing. Is this yet function for ORBI?
AniDutta
Jan 04, 2017Apprentice
DarrenM,
When is Netgear going to release an app that's functional? Look at what the competition ( Linksys) is offering for a similar priced product
DarrenM
Jan 04, 2017Sr. NETGEAR Moderator
Hello Anidutta
We do have a orbi app but it does not have those advanced features built into it yet.
DarrenM
- OrbiPhilipJun 11, 2017Luminary
DarrenM - It's been 5 months and the Genie app still does not support Wifi or Remote Access configuration. But the online documentation only references setting those us via the genie app. And in my case, Remote Access appears not to work properly when set up via the WebUI.
If the app isn't full baked, Netgear shoudn't be pushing it as the preferred config tool.- DarrenMJun 12, 2017Sr. NETGEAR Moderator
Hello OrbiPhilip
The genie app does not fully support orbi but does work in some cases I know that more features are coming with the orbi app but I have no ETA on this. The best way to use orbi right now is with the web ui.
DarrenM
- OrbiPhilipJun 12, 2017Luminary
DarrenM - Then why does all the documentation, including that posted here by admin ChristyT, indicate that we should use the Genie app? And were are the modified instructions telling us how to accomplish the same task in the WebUI?
