Nikon164
Jan 14, 2018Aspirant
Android/2.4-5 GHz switching potential fix
Good afternoon! For those having problems with Android/5 GHz devices dropping the wifi and picking it back up immediately, I have found a temporary solution. The problem with the LG G5 and Pixel ...
DarrenM
Jan 16, 2018Sr. NETGEAR Moderator
Hello Nikon164
Thank you for this feedback I will report your workaround to the engineers may help with the correct fix.
DarrenM
Nikon164
Feb 05, 2018Aspirant
Netgear,
I am sorry to say that this also did not work. It had the same problems as most of the other firmwares and configurations. I am done. The number of productive hours lost has now exceeded the value and utility of the product. Bought a Velop last week with no drops, restarts, or issues with Android. It really is too bad that you guys haven't figured the firmware and bugs out yet after the product has been out for so long. Done with Netgear now.
