AmitR
Jan 17, 2018NETGEAR Employee Retired
Announcing availability of OrbiOS 2.1
I posted this on a different thread, but copy & pasting it here for more visibility. Let me give you a quick update on where NETGEAR is with the OrbiOS. Just before Christmas break, we paus...
Bostonbill7727
Jan 17, 2018Tutor
Took update now nothing will work tried several reboots and nothing . How can I roll back to stable release?
- tagteamJan 17, 2018Virtuoso
You simply download the previous release (of your choice) and then do a manual update, ensuring you update the satellite(s) first. However, unless you disable auto-updates as set forth in the thread below (Message #105), you will ultimately be updated to the current release.
https://community.netgear.com/t5/Orbi/Firmware-V1-12-0-18-Discussion/td-p/1320421/page/5
- Bostonbill7727Jan 18, 2018Tutor
update: I rebooted the router and satellite with 2.1.2.18 this morning. knock on wood, everything is now running fine now. Hope it stays that way.
- ElyJan 18, 2018Luminary
Mine updated automatically, however the satellite did not update and it stayed on the older firmware, I had to re-install the older one on the router again, then manually update the Sat first and then the router, so far so good for the last few hours.
- sambillerJan 19, 2018Aspirant
I just updated to V2.1.2.18. I hope this fixes the fact that V2.1.2.10 crashed and rebooted on me this morning.
