AmitR
Jan 17, 2018NETGEAR Employee Retired
Announcing availability of OrbiOS 2.1
I posted this on a different thread, but copy & pasting it here for more visibility. Let me give you a quick update on where NETGEAR is with the OrbiOS. Just before Christmas break, we paus...
LHZ
Jan 21, 2018Guide
Is it just me or has AC and N mode somewhow being disabled after this upgrade to V2.1.2.18?
I get horrible throughput with speedtest.net from any orbi connected device. eg. 13Mb/s.
When I look in "inSSIDer" app - it shows Max Rate of 54Mbs.
If I test from the orbi itself I get the expected 115Mb/s.
Any ideas? I made no changes other than firmware upgrade.
guzzijason
Jan 21, 2018Apprentice
LHZ wrote:Is it just me or has AC and N mode somewhow being disabled after this upgrade to V2.1.2.18?
AC is working fine for me on V2.1.2.18.
One thing to check: make sure you have WMM still enabled in Advanced WiFi settings. Disabling WMM will automatically disable support for AC/N modes.
- LHZJan 21, 2018Guidethx for quick reply - that was indeed the case. enabled WMM and back to AC/N. weird that it was working for me before.
