AmitR
Jan 17, 2018NETGEAR Employee Retired
Announcing availability of OrbiOS 2.1
I posted this on a different thread, but copy & pasting it here for more visibility. Let me give you a quick update on where NETGEAR is with the OrbiOS. Just before Christmas break, we paus...
DLobo
Jan 25, 2018Aspirant
Thanks OrbiJ. Carefully optimistic that this (deactivating daisy chaning) helped me too. Since the update I had multiple RBR reboots every day, disconnecting my devices. Since unchecking the daisy chain option it has not rebooted.
(RBR50 with two RBS50, all on 2.1.2.18)
CopperSparks
Manually upgraded from Beta 2.1.2.10 which has been quite stable. CPU had dropped from 36% to 11.7%. Thruput through concrete floor to satellite to PC giving 98mb/s through 100mb/s fibre connection, 21 devices connected.
This release is looking good!, will check over the next few days for stability (2.1.2.10 was good already), but you guys seems to have the issue in hand at last, and are restoring my faith in my Orbi which, bar the Devember release fiasco, has been an awesome product.
Keep up the good work, this is ging in the right direction! Hope to switch firmware updtes back to auto in the coming weeks....
