AmitR
Jan 17, 2018NETGEAR Employee Retired
Announcing availability of OrbiOS 2.1
I posted this on a different thread, but copy & pasting it here for more visibility. Let me give you a quick update on where NETGEAR is with the OrbiOS. Just before Christmas break, we paus...
webminster
Jan 27, 2018Luminary
wrote:
I've seen it jitter a bit more when connected via a satellite, but really on an LAN you should not be seeing constant double digit ping times, that would indicate that your network is not happy and something is causing that latency.
I don't see "constant" excessive ping RTTs, as shown only random swings into them. The bulk of packets return in a few ms. I'll agree, something is causing it. As mentioned, the only change is the Orbi - going back to the ASUS restores the normal ping times. Pings from any box anywhere on the wired GB network to another shows consistent sub-ms RTTs.
aaz
Jan 27, 2018Virtuoso
Sounds like interference with the Orbi wifi. I assume you've tried changing channels, and did a network scan to see what else is around.
