AmitR
Jan 17, 2018NETGEAR Employee Retired
Announcing availability of OrbiOS 2.1
I posted this on a different thread, but copy & pasting it here for more visibility. Let me give you a quick update on where NETGEAR is with the OrbiOS. Just before Christmas break, we paus...
DarrenM
Feb 08, 2018Sr. NETGEAR Moderator
Hello pablofuente
Did you make sure that the satellite is on the exact same firmware version as the main router? also have you tried to enable beamforming and MUMIMO
DarrenM
pablofuente
Feb 08, 2018Aspirant
I did check firmware, yes exact same version. Both features (beam forming and Mimo) are enabled.
What else should I try??
- lcroslandFeb 09, 2018InitiateIs there a new Beta on available? This router was incredible for the first 4 months and now it is ABSOLUTE JUNK! Constant drops to internet. At least 20 times per day across all devices.
