AmitR's avatar
AmitR
NETGEAR Employee Retired
Jan 17, 2018
Announcing availability of OrbiOS 2.1
I posted this on a different thread, but copy & pasting it here for more visibility.
Let me give you a quick update on where NETGEAR is with the OrbiOS.
Just before Christmas break, we paused the distribution of OrbiOS 2.1.  Very soon, we're about to restart the distribution of a slightly updated version of the beta (2.1.2).  In addition to the major new features introduced in 2.1 (e.g. Circle, Ethernet Backhaul), this firmware is expected to address the high CPU issue, as well as the special character in PSK issue as well as support for the Outdoor Orbi.  Check Release Notes for complete list.
We are continuing to work on the issues with Google devices that have been documented in the press (several users have provided links here).
My recommendation is that you should either use the Orbi Mobile App (if you haven't seen it recently, check it out, we've made some major improvements) or the Web UI to check for new firmware or wait until your system gets auto-upgraded.
Link to RBK50 firmware & Rel Notes:  https://kb.netgear.com/000053549/RBR50-RBS50-Firmware-Version-2-1-2-18
Orbi Product Management
  • Been on 2.1.2.18 for a while now. Running very stable for me on my Orbi RBK53 (3 unit) system, as was 2.0.0.74
    I use Citrix to connect to work and also have one application which requires a constant connection and both are working well.
  • I rarely post about products but just have to say something.
    When I first bought my Orbi it worked great, but the last couple of months have been a nightmare.
    I do notice if I only use one satallite it seems to work better then when two are going.
    The problem is the Orbi was so expensive its hard to give up on it but the fustration just isnt worth it anymore.  I was at bestbuy today talking to them and they say they dont recommend it anymore because of what they are hearing.
  • Seems better now on new release. See below.
    I have rbr50 router and satellite.
    I was having 2 problems. Router dropping and not connecting and satellite not appearing on iphone app.
    I checked and my router was on the new current release 2.1.2.18. A router reboot changed colors on satellite but it did not appear on iphone screen. I tried unplugging it no difference.
    So, I went to part of out home that only satellite reaches. I tried a speedtest and it worked with good result. I looked at the iphne orbi app. The satellite now showed and it was prompting that an update to the satellite was available. I did the satellite update.
    Both router and satellite appear to be working ok now with good thruput, both on new release.
  • My router has been running for 17 days now without a single reboot. Speed is very good too running in AP mode.
    • Guytech's avatar
      Guytech
      Apprentice
      I did the upgrade to 2.1.2.18 and thereafter had several disconnects and random issues. I figured out that it was the wall plug satellite (RBW30 running 2.1.2.2)  causing the issues. Did a reset on it, setit up again, and since then everything is awesome with no issues at all! Great speeds and very stable! IIf having issues Isuggest maybe resetting the whole system after upgrade and try again.
      • timch's avatar
        timch
        Luminary
        My RBK53 has been running 25 days now, couldn’t be more pleased with the reliability, range and speed.
  • I see too many complaints with Netgear orbi system. As far as my experience, I am running router and two satellites system for more than 3 months without any issue. All units are auto updated to latest firmware. Reading all the complaints, it
    • wildhorse's avatar
      wildhorse
      Star
      I'm not experiencing problems other users are having with 2.1.2.18 firmware. My setup is simple though - one router (ground floor) + one satellite (1st floor), both not far from staircase. I do not need more satellites. Devices include smartphones, TV, laptop. There do not appear to be any problems when moving between router-satellite repeatedly and no high CPU usage.
      • heyeaglefn's avatar
        heyeaglefn
        Guide
        Having problems with this and every release since the .74 release.  I think those that aren't seeing the problem may not be noticing it because your uptime still remains the same so you actually have to see it.
        My probably is my Satelite dropping it's connection, which means my hardwired devices losing connection temporarily throughout the day for about 20 seconds.  I see it pop up on my screen on my computer or I dropped a phone call because of it.  Be playing xbox and it will just drop the connection.  None of this happened on .74 but every release since it has happened.
        Can't believe Netgear won't let me stay on .74, always auto updates and nothing I can do to fix this issue on any of the new firmware.
