BigRune
Feb 25, 2020Apprentice
Another RBR50 Dropping Internet Connection
OK, so now I just about had it with this Netgear setup I bought. Seven week old setup of RBR50 and a wired RBS50. fwV2.3.5.30 on both devices.Router Connected to a CTS HES 3106 Fibre converter s...
- Feb 26, 2020
Today I feel total relief. I returned the RBK50, got a total refund and installed my old ugly, no-app, rock-solid AC3200 router.
Could not imagine a product that flawed would still be in the shelves. Good luck you all with future firmware uppdates and endless discussions what equipment this malfunctioning piece of garbage is,connected to :smileylol:.
TheGarbageMan
May 14, 2020Initiate
Ekhail, you are my freakin hero! We just purchased the orbi system, and it seemed like a great fit for our house. Our old Asus router developed an issue after three years where after about 1-2 days of up time, you would start getting 2-3 second lag spikes when gaming. Not cool. I got tired of resetting it all the time, and decided to upgrade. There doesn't seem to be a lot of good routers out right now. All of them appear to have some issue or another. The orbi looked like it was free of most of those issues. But, after about 2-3 days of use, it dropped our Wan. Wifi was fine. I knew it was the wan because even my wired devices dropped off the internet. At first, I thought it was related to parental controls, or something like that. So, I disabled all of those. Didn't help. Next I searched the internet... found nothing helpful. I contacted netgear support. What a joke that was. They asked a million questions, and wanted me to change my DNS settings to google's public server. Look, I'm oldschool... I was microsoft certified for windows NT 4.0 enterprise. I've been around. I knew this was not a DNS issue. I was all set to pack it up and ship it back when I rememberd back in the day when I went to lan parties. back then, no one had DHCP servers or routers with DHCP. We had a white board, and everyone wrote their name next to an IP address and manually assigned. The system worked great until that one plebeian who never changed his settings from the last lan showed up and created an IP conflcift. That's when it hit me... this was acting just like an IP conflict. So, I changed my key word searches for a fix, and stumbled upon this thread. I made the changes, and sure enough.... been up for a week without incident. What annoys me more than anthing about this whole situation is that Netgear broke this with a firmware patch MONTHS ago, and still hasn't fixed it. What annoys me even MORE is that they HAVE to know this is an issue by now. What annoys me EVEN MORE than that, is that this was not the first thing presented to me as a fix when I contacted support. What a joke. But, I digress. Thank you for the fix... you saved netgear a return.
TimmyTechTV
Jun 08, 2020Tutor
This thread is huge. Which suggestions worked for you because I'm about to Office Space mine...
TheGarbageMan wrote:"I made the changes, and sure enough.... been up for a week without incident."
- FURRYe38Jun 08, 2020Guru - Experienced User
Let us know if this helps:
TimmyTechTV wrote:This thread is huge. Which suggestions worked for you because I'm about to Office Space mine...
- BigRuneJun 08, 2020ApprenticeNever been happier đđ: https://store.ui.com/collections/unifi-network-routing-switching/products/unifi-dream-machine
- TheGarbageManJun 08, 2020InitiateThe fix posted by Ekhail worked for me.
You need to telnet into your router and fix the Ip lease time.
Just follow the directions. Itâs not super complicated. If youâre running Windows 10 you may need to enable telnet first. Itâs built into windows but not enabled by default. You can google how to turn it on.
Been up for weeks now without incident. - ekhalilJun 09, 2020Master
