alokeprasad
Jan 02, 2021Mentor
Any special instructions for _downgrading_ firmware?
I'm considering taking the plunge and manually updating my firmware to 2.7.1.60 (and then on to 2.7.2.102). In the worst case, I can downgrade back to 2.5.2.4 (and restore my settings from backup...
CrimpOn
Jan 02, 2021Guru - Experienced User
Yes, the same instructions apply. Satellites first, then router.
Good Luck.
- FURRYe38Jan 02, 2021Guru - Experienced User
What CrimpOn said. :smileywink:
- plemansJan 02, 2021Guru - Experienced User
I've also made to sure only change firmwares over a hardwired connection if at all possible.
- alokeprasadJan 03, 2021Mentor
Followed all the steps and updated to 2.7.1.60 manually and to 2.7.2.102 automatically without any hiccups.
The devices retained their settings and are working at the same speeds as before the update.
