schpeen
Oct 13, 2016Tutor
Anyone order an additional Orbi Satellite ???
Has anyone else ordered an additonal Orbi Satelite for their Orbi system?? I have a big home so I just ordered an additonal satelite I am anxious to see how it will perform with 2 Satelites. Anyone h...
peteytesting
Oct 13, 2016Hero
hi,
so i assume you have got the orbi system already and have tested out with the router and sat ? and assume it still doesnt cover everything
you will need to ensure the router part of the orbi can be situated between the first and second sat as at this stage the orbi system runs in star topology and thus both sats connect back to the router only
so you have it setup like
sat ------ orbi router --------sat
with the internet connection at the router
wont work if you have say
router ----------- sat -------------- sat
as the second satstill needs to connect back to the orbi router at this stage ( may change if the orbi gets mesh )
also i have a 4,000 square home and the single orbi router and sat cover it with ease , how big is your place / or are we talking multi story
pete
schpeen
Oct 13, 2016Tutor
Hi Pete...I am fimilar with how it needs to be setup and how it works. Yes...I currently have one. I was just curious if anyone had tested with 2 satilites. My house is about 3,900 sqare feet but its multi level. So my plan is main Orbi Router on main floor and satilite upstairs. But I also have a huge finshed basement as well that is not in the above square footage, 3 car garage and huge patio area so my plan is to put other Orbi satilite in that area. I currently get coverage there now with my current Orbi setup but its not perfect............one more should do the trick and no matter were I go I will have awesome speeds and coverage. According to Netgear as long as the satilite can reach the main Orbi Router it will work.
