youngr1
May 24, 2019Aspirant
Anyone use satalites with haulback to extend the SSID or network (not expecting MESH accoss them)
Not sure why the RBK43-100NAR does not show up in the list so had to take the RBK53.
Anyway I want to use the router and 2 satellites in my home and then I have 2 out buildings in my properties that I have hardwired back to the house. My question is can I add a 3rd and 4th to those buildings adding via backhaul over hardwire to extend the wife hot spots? I know i can not MESH across them with a device handoff but just one one SSID and one network schema. Right now I have internet access in each outer building but on a diff ssid and diff subnet and want to clean this up. So in the end I would have 5 (one router and 4 satellites) then not sure if I can use the last router as a satellite as well. (Would get 2 kits).
Yes you can add additional RBS satellites via ethernet back haul.
RBRs can't work as satellites, only in AP mode or router mode.
Be sure that Daisy Chain is disabled. Under Advanced Tab/Advanced Settings/Wireless Settings
