Spidde
Aug 09, 2019Aspirant
AP-mode, Multi-SSID, VLANs and backhaul.
Hi! I´m thinking about investing in an Orbi-solution but have not been able to find any information that states that all my requirements is supported, at the same time. I´m attaching a sketch of the...
Aug 09, 2019Guru - Experienced User
Most likely not. Orbi doesn't support separation of SSIDs let alone making each freqency go to a separate VLAN.
Sounds like you need something more business or enterprise supporting. Orbi is for home.
