Spidde
Aug 09, 2019Aspirant
AP-mode, Multi-SSID, VLANs and backhaul.
Hi! I´m thinking about investing in an Orbi-solution but have not been able to find any information that states that all my requirements is supported, at the same time. I´m attaching a sketch of the...
CrimpOn
Aug 09, 2019Guru - Experienced User
I agree with FURRYe38 . This is not what Orbi is designed for. Will be a dismal failure.
I wonder what prompts this design. "super paranoia?" belief that somehow traffic on VLAN's adds up to less useage than traffic on a single LAN? It just seems like a whole lot of bother.
Good Luck
- Ragar99Aug 09, 2019Luminary
CrimpOn wrote:I agree with FURRYe38 . This is not what Orbi is designed for. Will be a dismal failure.
Good Luck
There are plenty of reasons. Separation of traffic so you can prioritize more easily, segments that don't need internet access off the top of my head.
