Majorninth
Aug 12, 2017Aspirant
Ap mode or router orbi rbk50
So I unboxed the system plugged it into my wired network and set it up. Software updated to the latest version. As far as I can tell everything works fine. After viewing this forum I find out the la...
st_shaw
Dec 03, 2017Master
If the Arris takes a public IP on the WAN interface and is acting as your router, serving up LAN IP addresses via DHCP, then you should set Orbi into AP mode. This is usually the simplest to setup.
If you already have an extensive Ethernet network that's working, you can leave all existing equipment as it is (except you should disable WiFi on the Arris), and just plug Orbi into the LAN somewhere, and set it up for AP mode.
seurat0109
Dec 03, 2017Aspirant
Thanks for the comments. Following are some additional questions:
1. Assuming that a Comcast gateway (modem/router combination) is set up as you described in the first paragraph, I would assume the gateway should not be in bridge mode. Is that correct?
2. Also, does IP passthrough have anything to do with operating in AP mode? If so, how is that done?
3. My understanding is that setting the gateway to non-bridge mode can be accomplished by connecting a laptop directly to the gateway. Is that correct, or would I have to contact Comcast support? I'm thinking that Comcast would have to reset the system, but I'm so confused at this point, that I have no idea.
- st_shawDec 03, 2017Master
1. It depends on what other equipment you have. If you have antoher router on your network, the Arris could be in bridged mode. If the Arris is the only box, then it cannot be in bridge mode.
2. IP passthrough is sometimes used when a real bridged mode is not available. This will pass the WAN IP through to a secondary router.
3. Usually the end-user can switch between modes by connecting a laptop. This can be confusing unless you've done it before because the modem might appear to stop responding. Sometimes bridged mode is disabled and requires a call to your ISP to enable.
Also keep in mind that if you have extensive wiring in place now, and you setup the Arris in bridged mode, you will need to move all your wiring to terminate on the Orbi router ports, not in the Arris ports.
My suggestion was this: Forget about bridge mode. Set everything back to how you had it before Orbi, plug Orbi into the LAN, configure Orbi for AP mode, turn off Arris WiFi, and you are done. You don't need to change any wiring either. All you need to do is wire the Yellow Internet port on Orbi to some point on your existing LAN. Much easier.
- RobertWycoffDec 03, 2017Aspirant
st_shaw wrote:1. It depends on what other equipment you have. If you have antoher router on your network, the Arris could be in bridged mode. If the Arris is the only box, then it cannot be in bridge mode.
Hmm. I like that. Do I still use the Orbi Ethernet port for my connection to my Arris?
I'm not exactly sure what you are asking. You connect the Yellow Internet port on the Orbi RBR50 to an Ethernet port somewhere on your LAN. Normally you would connect it to a LAN port on the Arris. But, you can connect the RBR50 somewhere else in the house, if that puts the RBR50 in a better central location. After the RBR50 is connected, you can connect other devices to the Ethernet ports on the RBR50 and RBS50--they act like switches.
After some thought, I am going to bridge the Arris and follow the instructions and make an ethernet connection from Port 1 on the Arris to the Ethernet port on the RBK50. Then I will connect my 8-port gigabit switch to an RBK50 Lan port.
My understanding is that with this setup, the Orbi becomes my router, replacing the Arris. Hopefully, the Arris will continue to support Xfinity Voice and Xfinity Home, which the Orbi can't do.
Whether all this works will only be known when I try it. My wi-fi is so bad, I will do ANYTHING to make it better.
- RobertWycoffDec 10, 2017Aspirant
seurat0109 wrote:Thanks for the comments. Following are some additional questions:
Regarding bridge mode, I am able to log into my Arris and change it to Bridge Mode if I need to. No need for help from Comcast.
- seurat0109Dec 10, 2017Aspirant
Robert,
Yes you can do that but you will lose the ability to reach the gateway over wifi if you put it in bridge mode. If you subsequently want to change back from bridge mode you will have to access the gateway via a hard connection or contact your ISP.
Wayne
seurat0109 wrote:Robert,
Wayne
I am not concerned about reaching the gateway over wi-fi, because I have several computers connected to the ethernet network which includes some gigabit switches to reach everywhere.
I am mainly trying to replace the Arris wi-fi with Orbi w-fi.
But I need to make sure I don't have a double-NAT situation.
