Forthay
May 22, 2018Tutor
App Functions Disabled in AP/bridge mode
Hi, I’m still trying to find my BT Whole Home replace. I read the Orbi app has the following features
- Set up your Orbi system
- Enable Circle with Disney Smart Parental Controls to manage content and time online
- Enable and set up guest WiFi
- Share WiFi credentials with others
- Change your network name (SSID) and password
- Check the connection status of your Internet and Orbi satellite
- View the devices that are connected to your WiFi network
- Add an Orbi satellite to your existing Orbi system
- Pause and resume WiFi on the devices that are connected to your network
- Run Internet speed tests and view your speed history
- Monitor data usage using the traffic meter feature
- QR code WiFi sharing
- Enable/Disable remote access through the app
- Network Map to display all connected devices on your network
Does anyone have a list of what app feature are not available in bridge mode?
I’m mostly interested in whether any or all of these are available.
I am in AP mode and all of those functions are available.
Those features should be available in AP mode.
There is no Bridge mode for the RBK50 series...
- ForthayTutor
Thanks FURRYe38 this really helps me, sincerely appreciated.
By chance, and only after your reply I found https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode too but it doesn’t explicitly refer to the app itself.
- tsigLuminary
