Dubs89
Jun 24, 2021Follower
App Issue - Using 2 RBR50 routers (one as an Access Point)
I purchased 2 of these routers with 1 satellite for each. Upstairs: - I set my Telus modem to bridge mode. - I set one of my Netgear routers and connected it to my Modem (Port 1). - I set up a s...
Jun 30, 2021Guru - Experienced User
Any progress on this?
Upstairs:
- I set up a satellite and have it connected to this router.
Downstairs:
- The second router I purchased I set up as an Access Point by logging into OrbiLogin.com and using the setting there. Used dynamic DNS as recommended.
- Ran a cable from the upstairs router and plugged it into the router I set up as an Access Point.
- The second satellite I set up downstairs and it seems it is connected to the Access Point router.
Both the Access Point and Main router have the same Wifi login (username and password) so it seamlessly switches between them.
My issue is that when logging into the Orbi App and the Circle App I get which ever router I am connected to at that moment. So I don’t get all my household devices on either App, only what is connected to whichever router at the time.
I thought you could not use the Orbi app with a router in Access Point mode, did I miss somthing when setting up the access point (I followed the directions in the help section on this website, just logged in and selected the setting.)
Any help would be great! Thanks!
