CarlCO
May 26, 2018Aspirant
Apple Expresses keep dropping
My home wifi system has been spiraling out of control... it was working alright with my ASUS router but I didn't have enough range so I picked up the Orbi System (base with one satelitte).
I h...
st_shaw
May 26, 2018Master
Not sure how you have things setup, but you do not want more than one device broadcasting WiFi. That will cause problems. Turn off the WiFi radios in your Airport Express units and connect them to your network using Ethernet. Orbi should be the only SSID available.
CarlCO
All the airport expresses are set to join an existing network, so I don't believe that is the issue.
My expresses are too far to hardwire (via ethernet)
- st_shawMay 26, 2018Master
It might not be convenient, but a wired setup would be better. You can connect the Airport via wire to the Orbi router or to any Orbi satellie, and you can use a long cord, so you should have some flexibility in where you place things.
In any case, you should try the Airports in a wired setup and see if that resolves your issue. Then you can go from there.
See the instructions in this article. Are the Airport devices set to bridge mode, as described in the article?
http://www.theinstructional.com/guides/configure-an-airport-express-as-an-ethernet-airplay-receiver
- CarlCOMay 26, 2018Aspirant
Sorry... but that's just silly. The airport expresses have worked wirelessly for years with other routers. This problem is strictly related to the introduction of the Orbi system and I will replace the Orbi's with a mesh system that functions how I want it before running wire thoughtout my house.
