TheElSean's avatar
TheElSean
Follower
Feb 21, 2019
Apple TV 4k loses connection to Orbi RBK 50 AC3000
Just setup an RBK 50 with one sattelite and all was well.  The other day my Apple TV wouldn't connect to the internet.  Resolved itself a few hours later.  Then today it happened again.  It shows a connection to Wi-Fi, and I can even run the speed test app on the apple tv and it gets a speed back, but when I try to open any app, it says not connected to the internet.  Tried restarting Orbi / Apple TV and nothing worked.  Once again a few hours later it was working again for a while, then stopped.
I've had the Apple TV working fine for over a year until I installed the Orbi.  Is there something wrong in my Orbi config?
  • Seems like another double NAT issue. If your ISP modem is acting as a router and does NATing on the incoming WAN traffic then this can cause different issues since Orbi is also doing NATing. You need to check if you have double NAT.
    Please open a Command Prompt on any computer attached to Orbi and type:
    tracert 8.8.8.8    (traceroute to Google’s DNS server)
    1. If you see two private IP addresses listed in the first two hops then you have double NAT. Please check the model of your ISP modem and if you have a manual for it.
    2. If you see only one private address and the second hop shows a public address, then you’re all good and we need then to troubleshoot further to find the root cause of the issue,
  • FURRYe38's avatar
    What FW is currently loaded?
    Is the Orbi system operating in Router or AP mode?
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
    What WPA security modes are you using?
    Try enabling Beamforming and MIMO.
    Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
