vbmike73
Mar 09, 2021Tutor
Apple TV 4K will not connect to Orbi RBK50 via Ethernet
I have an Orbi mesh system and two Apple TVs (4K and 4HD versions). Both of these Apple TVs will connect to the WiFi with no issues. However, I cannot get either one to connect via ethernet. I have...
nixname
Jul 08, 2022Aspirant
This is the strangest thing. I have 6 Apple TV's. All have worked fine, no issues for a few months. (Wired). All of a sudden, none of them connect wired. They all connect with wifi no issue, but they can't find the router. I've fully reset the Apple TV's..no luck. I've rebooted network, no luck. I guess my only choice is to reset the network. What an odd glitch!! Wondering if you found any other solutions?
- vbmike73Jul 09, 2022TutorIt must be a known issue but they’re not broadcasting it. They had me send in my device and they repaired it free of charge. Something with the Ethernet port itself going bad. After they did that, I’ve had no issues. Beat of luck!
