Andy1205
Jul 12, 2018Aspirant
Are Rs40 satellites compatible with RS50 router?
Hi I have a RS50 with 2 RS50 satellites. I have bought another RS40 satellite to cover a small remaining black spot. However, the RS40 struggled to connect even when in the same room. When it did, it...
Andy1205
Thank you.
Are there instructions on how to update the FW using a PC?
Jul 12, 2018Guru - Experienced User
Try connecting the RBS40 via wired to the RBR50 router, look up to see what IP address it gets from the RBR router, if you can get an IP address on it, connect a PC to the back of the RBS other port with a PC and navigate to the IP address the satellite got from the router in a web browser...Then manually upload the FW file for it.
