ScoopOZ's avatar
ScoopOZ
Follower
Dec 18, 2016
Arlo + Orbi
I am having problems connecting an Arlo Q camera to Orbi Router. The Arlo Q connected via a Windows based PC. The Arlo Q camera won't connect either via PC or App neither will my Ring doorbell.
1 Reply
    I am running the same setup , Arlos Qs and Arlo base/cameras with Orbi
    The Q camera has no problem hooking into the 5ghz of the Sat ( running .16 sw ).
    From what I read, the Nest has it's own problems... but the Q shouldn't have any problems at all.
    Concentrate on one at a time as I feel they are apple/oranges.
    As to the Q, I would do a full reset ( hold in the reset for about 10 sec till the led flashes... then re-sync it as if new ) See if this solves your connection problems.
