dariesng
Jan 05, 2019Aspirant
Arlo Q Streaming Issues with Orbi RBK50
I recently replaced my old router with the Orbi RBK50 and all my devices (phones, laptops, TVs) work fine and have seen the benefit of faster speed except for my Arlo Q Camera. (Windows 10)
Th...
ekhalil
Jan 05, 2019Master
ekhalil wrote:
I would guess that the camera is far away from Orbi and that's why it selects the 2.4 GHz band. Have you checked in connected devices if it connects to the 2.4 or 5 GHz bands?
- One way to force the camera to choose the 5 GHz band is to reduce the transmission power of the 2.4 GHz band, can you please try that?
- Otherwise please make sure Implicit Beamforming is enabled which will boost wifi speed and range.
Also it seems that Arlo Q has N600 wifi which means that it supports MIMO. Please make sure that MU-MIMO is enabled in the advanced wireless settings.
I'd start by testing the Beamforming and MU-MIMO first and then go to test the Tx power reduction.
Good luck
dariesng
Jan 06, 2019Aspirant
Test reply
