bigfellanz
Dec 08, 2018Guide
Armor on Orbi?
So Orbi has been added to the "available on" section of the Armor page (https://www.netgear.com/landings/armor/#formsubmit) - but there is no relevant instructions on how to activate it. Has anyone h...
randomousity
Dec 08, 2018Luminary
I think that must have either been premature on Netgear's part listing the Orbi, or a mistake. Either way, there are only two router models listed there now (Nighthawk AC2300 R7000P and AC1900 R6900P). It would be interesting if they add the Orbi to the list of compatible devices, but it doesn't seem to be available now, which would explain the lack of instructions for installation/configuration/activation.
bigfellanz
Dec 08, 2018Guide
So I still see four routers - https://imgur.com/a/m6Mm0fI
Actually, to make this a bit wierder, on my machine it's browser dependent whether the Orbi shows up, but even when it isn't visible it's still in the page source.
The Orbi Voice was announced three months ago, so it's unlikely it's a hangover from the original Armor annoucement.
- FURRYe38Dec 09, 2018Guru - Experienced User
You link isn't working:
Zoinks! You've taken a wrong turn.
Let's split up, gang. If you're looking for an image, it's probably been deleted or may not have existed at all."
- bigfellanzDec 09, 2018Guide
Sorry, a space snuck onto the end of that link -https://imgur.com/a/m6Mm0fI
- randomousityDec 09, 2018Luminary
So, I see two Orbi models in the source code: the RBK50 and the RBK50V. But I loaded the page in both Chrome and Edge, and only the two Nighthawk models actually render on the page. Very odd. But my guess is, they're planning to add support for the RBK50 and 50V, but don't want to announce it or commit to a release date yet.
