AR247
Sep 20, 2018Follower
Armor vs BitDefender box2
First - when will Amor be available for Orbi (in the Jan 2018 press release it was promised before the Nighthawks) ?
Second, what is the difference in feature set between Armor and the Bitdefen...
Christian_R
Sep 20, 2018NETGEAR Employee Retired
Hello AR247,
As stated in the press release:
"To be first introduced on the Nighthawk AC2300 Smart WiFi router (R7000P) later this quarter, NETGEAR Armor will be made available for the Orbi Whole Home WiFi system and the popular Nighthawk performance routers later in the year via firmware updates."
You may find more information on NETGEAR Armor in the link below:
https://www.netgear.com/landings/armor/
~Christian
- ClevelandiusSep 20, 2018TutorThe difference is the Box 2 exists. Much better security than the non-existent Armor for Orbi.
- loomis1975Sep 21, 2018Luminary
Bitdefender box 2 makes you put your wireless router into access point mode (bridged). Goodbye advanced router features.
- ClevelandiusOct 10, 2018TutorAt this point I no longer believe this product is actually going to be released so I'm going to live with the reduced functionality. It seems like a good trade-off for me, reduced functionality and a security product that exists, vs waiting for something that will never be released.
