UP4278
Jan 02, 2021Aspirant
Assign Guest Network to Satellite LAN ports
Hi there,
I am wondering if it is possible to configure the LAN ports on the satellites to connect to Guest Network?
I am hooking up a printer on that port, I would like it to be accessible from the guest network.
Router is RBR20, Satellites are RBS20.
Thanks
UP
UP4278 wrote:Hi there,
A printer available only to the Guest network? Interesting. How about an inexpensive WiFi Extender, such as a TP-Link N300, available on Amazon for $20.
It has one ethernet port that can be used to connect a printer that lacks WiFi. Pair it to the Guest 2.4G network.
Sort By
- alokeprasadMentor
Assigning guest network to the ethernet ports on the router or the satellites is not possible, AFAIK.
- alokeprasadMentor
Pair a range extender to the Orbi guest network and use the range extender's ethernet port ... Brilliant!!
