sfjames's avatar
sfjames
Guide
Jan 23, 2017
At the end of my rope with my Orbi
Have been working with support to no avail. It goes like this. Orbi directly connected to my modem fills it log files with
DoS Attack: ARP Attack] from source: xx.14.79.65, Monday, January 23, 2017 17:38:27
[DoS Attack: ACK Scan] from source: xxx.101.40.116, port 443, Monday, January 23, 2017 17:38:27
put my old 7000 in between and nothing in its log files or the 7000
cable company has given up giving me new ip addresses tried 2 versions of the modem nothing. 7000 works fine alone but wifi never made it to rest of the house. I could run orbi in ap mode that works but i just cant figure out what is wrong. any suggestions? Clearly not a network engineer here,
  • I disabled the logging of those issues and just keep track of the system related ones.  If it's rejecting attempts, it's working as it should.
    • Ely's avatar
      Ely
      Luminary
      You are worrying about some DoS/ARP Attack warning logs in your router? that's completely usual these days, almost everyone gets those every once in a while, I would worry if my router never warned me about those, does it bother you to see the logs? disable logs then, your Obi is doing exactly what it is supposed and designed to do.
      • Thanks for all your comments. While at the highest level I get it and thats what support is yackign about I would like it to make sense and I guess its just never goiing to. Let me be clear when my 7000 is the router alone with my modem and everything is connected exact.ly the smae way nothing in the log files for attacks. When you connect orbi it is attacked hundreds of times per hour all day long which does seem at times to effect performance. When you pur the orbi behind the 7000 again nothing in the 7000 or the orbi log files.  IT doesnt make sense all things being equal. As I mentioned tried new ip addresses etc my casble company has been very accomodating in trying to help but has given up. They were concerned becasue all teh attacks appear spoofed from them thats teh trace on the ip but they say they are nto doing anything.  Thanks.
  • This is a netgear firmware logging "feature".  R7800 and Orbi log these events more than any other routers.  R7000 also logs them to a lesser extent.  When I load DD-WRT on my r7800 or Tomato on my r7000 I never see the events even though my IP is the same.
