russellmoran99's avatar
Apr 20, 2017
AT&T MicroCell randomly disconnects using Orbi
I have an AT&T MIcrocell which is plugged into the Orbi Router firmware 1.8xxx to boost my AT&T signal.  If you are not sure what a microcell is, it is designed for homes that have weak signal to boost if using wifi.  When it works, it is perfect.  The problem is since I have installed Orbi it doesn't work properly.  If I make or receive a call the Microcell seems to work fine as long as I stay in 1 location. If I walk around my house, I lose the Microcell signal.  My phone disconnects from the microcell.  It happens with all phones in my house.
I believe this to be a Orbi issue.  I think when I walk around the house I pickup a new Orbi satellite (I have 3 so far) and that's when I believe I lose the signal on the Microcell.
Anyone else have a problem like this and a solution?
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Russellmoran99
    I do not understand why wifi would interfere with the microcell since it puts out its own phone signal and wouldn't be using the wifi. I would try turning off the wifi on your phone and test it out again.
    DarrenM
    • MarkC1024's avatar
      MarkC1024
      Luminary
      I doubt it interferes, but most likely when moving between router/satellites the disconnect/reconnect is dropping his call.  The microcell probably isn't designed for it's connection/signal to be "handed off".
