TeamLevine
Aug 02, 2018Aspirant
AT&T Uverse Cable Not Working With Orbi RBK50 (AC3000)
When connected through my Orbi RBK50, my AT&T Uverse cable is not working. Does anyone know how to get all Uverse receivers working properly with the Orbi router (NOT in AP mode) based on the setup b...
Aug 07, 2018Guru - Experienced User
Possible that a double NAT condition is having an effect on your devices.
So if you re-configure the orbi for router mode, place it's IP address it gets from the ISP modem into the modems DMZ, this doesn't help make the Uverse devices work? No switches in the mix...With out having the Pace modem bridged, I believe you maybe stuck with AP mode with the Orbi in this configuration with your UVerse devices...
