ATTUverseUser
Oct 31, 2016Follower
ATT Uverse
I am an ATT Uverse user and interested in the Orbi product. Has anyone set up the Orbi on the ATT Uverse system? Uverse system has the modem/router in one device. I'm not a network guy so do not unde...
TheEther
Nov 02, 2016Guru
Great response. Note, you can even use the NVG599's Wi-Fi to provide a guest network. This should tide you over until Netgear adds guest network capabilities to the Orbi.
itsmecramer
Nov 02, 2016Initiate
Thanks! And yes, that did cross my mind earlier as I was going through the Orbi config and noted the lack of a guest network. I'm assuming this is simply a software issue and isn't a hardware matter, right?
- TheEtherNov 02, 2016Guru
If I were to guess, then yes I believe this is a software issue. I'll bet that they haven't implemented guest isolation across the base and satellite(s).
