only1mrsj
Apr 01, 2017Follower
AT&T Wifi / Hotspot
Hi! I have AT&T as my cell phone provider. I can't access their Wi-fi since my home sits on a deadzone - per AT&T. I use their Mobile Hotspot okay. Will the Orbi help me use the Wi-fi option or will I have to keep turning on the Hotspot? Will it work with the Hotspot? Thanks!
The Orbi by itself won't work with the hotspot. It requires an Ethernet connection to the Internet. You could kludge something together by using a range extender, media bridge, wireless bridge or gaming adapter:
Hotspot---Wireless bridge---Orbi in AP mode---Devices
+---DevicesNot the most elegant solution.
- st_shawMaster
only1mrsj wrote:Hi! I have AT&T as my cell phone provider. I can't access their Wi-fi since my home sits on a deadzone - per AT&T. I use their Mobile Hotspot okay. Will the Orbi help me use the Wi-fi option or will I have to keep turning on the Hotspot? Will it work with the Hotspot? Thanks!
You can buy a 4G LTE router (like a MOFI or CradlePoint). It will connect to the AT&T service for Internet and provide WiFi throughout your house.
Ah, I forgot, Netgear also has a LTE router, the R7100LG.
