GWild
Mar 04, 2019Guide
Attached Device List
CBK40 kit ...
Attached Device list seems limited to 7 devices, with no scroll capability. When more than 7 devices connected, only the first 7 to grab IP's are shown.
Separate issue, a suggestion to upgrade the satellite firmware isn't happening because the satelitte isn't recognizing the default password nor the one the master was set to. At least through the 'manual' web interface to it. I did upgrade firmware using the 'more or less automatic' update function.
Have you powered OFF the satellite for 10 seconds then back on to see if it re-syncs and you can access the satellites web page and log in. Sometimes it gets out of sync and doesn't receive the information from the CBR.
If the power cycle doesn't fix this, try a reset on the RBS. Factory reset the router using the back push pin button. Hold it in until the top led turns on AMBER then let go. Wait for the WHITE led to slowly pulsate, hit the black sync button on the CBR then the RBS. Wait for the top led to turn BLUE. Then go off.I updated this past weekend on mine. I manually downloaded the FW file and manually sent it to the RBS.
- GWildGuide
The satellite is chatting with the master - showing connected devices and this machine I am typing on (using satellite as a bridge and slave but not in bridge mode). Satelitte connects to switch, which other machines connect to.
What is the Mfr and model# of this switch?
I would remove the satellite temporarily from this switch and connect it wirelessly to the CBR. Do this in the same room as the CBR. Once it's connected there. Try the manual FW update with the satellite.
