gtmead09
Dec 03, 2020Guide
Attached Devices not correct
Running firmware 2.6.1.40 and having issues with the attached device list. Some devices don’t show, I fixed one by manually setting a dhcp reservation, but that is not sustainable. Basically if I brow...
Dec 03, 2020Guru - Experienced User
Try a factory reset to see if this resolves the problem, if not, downgrade to v16:
gtmead09 wrote:
Running firmware 2.6.1.40 and having issues with the attached device list. Some devices don’t show, I fixed one by manually setting a dhcp reservation, but that is not sustainable. Basically if I browse to the satellite I can see it as a attached device. It has network connectivity as well. I also downgraded from 2.7.1.60 in hopes it would fix it. Reset would be absolute last resort and I am not sure this is big enough to justify. Any suggestions to try?
vajim
Dec 03, 2020Master
:smileyhappy:
