fredsocial
Dec 12, 2017Tutor
Attached Devices not showing after V2.1.1.12 firmware upgrade (RBR50)
I noticed that several people are complaining about the fact the Attached Devices are not longer showing after V2.1.1.12 firmware upgrade (RBR50). I have the same problem. Does anybody were able...
fredsocial
Dec 18, 2017Tutor
Thank you. Any update on this?
ratickle
Dec 19, 2017Apprentice
Orbi firmware version 2.1.1.16 has been release. The release notes say this version specifically addresses the problem of attached devices NOT being listed by the satellite web interface.
I installed 2.1.1.16. At first the satellite WAS showing attached devices, but after four hours of uptime, the list of attached devices being shown by the satellite web interface are gone again. To me, it looks like version 2.1.1.16 did NOT fix the problem.
- webminsterDec 19, 2017Luminary
Confirmed here, problem still exists in .16 firmware.
- mpf541Dec 19, 2017Apprentice
on the .12 firmware mine took a couple days to start showing connected devices. I upgraded to .16 today and all my devices are still listed. I did have a wall plug sat that connected to the main router and had a poor connetcion but rebooting it it reconnected to the closer wired sat and now has a good connection.
Now I just hope they all stary working properly
- aazDec 19, 2017Virtuoso
webminster wrote:Confirmed here, problem still exists in .16 firmware.
For those saying they are still having problems in .16 firmware maybe try re-deploying the firmware update again - first satellites - one by one, and then the router. Make sure you have the proper firmware for the satellites and the router.
This update is working well for me but it's only been about 2 hours now. Will report if there are any issues - but, cross my fingers, so far none. This one looks like the one.
- JMU1998Dec 19, 2017Luminary
It has been about 5 hrs and issue returned, I even did a factory reset on both after the firmware update
