fredsocial
Dec 12, 2017Tutor
Attached Devices not showing after V2.1.1.12 firmware upgrade (RBR50)
I noticed that several people are complaining about the fact the Attached Devices are not longer showing after V2.1.1.12 firmware upgrade (RBR50). I have the same problem. Does anybody were able...
bsorrent
Dec 29, 2017Guide
I had to downgrade from 2.1.1.16 to 2.1.1.12 due to a number of unrelated issues to the attached devices not showing. All of my devices were showing in 2.1.1.16 but they are not in 2.1.1.12 (even wired devices are not showing). Netgear is telling me that they don't want me to update my firmware until/unless I need to due to performance issues. I would very much like to see all of my devices. I will wait a few days to attempt to update the firmware to ensure I have a stable network as I recently spent 8+ hours getting it working.
bsorrent
Dec 29, 2017Guide
I forgot to inlclude an answer to the person who was worried about support after the 90 days. It's not an issue, Netgear has extended support to Orbi users beyond the 90 days (I personally think it's due to the fact the bugs are not worked out of this product as I have spent at leat 5 days worth of hours getting this thing working over the past 5 months).
- nycjokerJan 01, 2018InitiateAny word from Netgear on a permanent fix? The latest firmware for .16 is losing the device list after some time. Rebooting the satellite and reconnecting it fixes the issue for me but for a short period of time.
- tagteamJan 01, 2018Virtuoso
nycjoker wrote:
Any word from Netgear on a permanent fix?...Yes, next release, purportedly:
- atiq332Jan 01, 2018Star
hope so they fixed this time, actualy v2.1.12..and the lated v2.1.1.16 wont do the job, still facing same issue.. auto reboot. automatic ip changed. some the connected devices are not showing even they connected. satellite are connected with router but some time not a single device are connected.. i purchaed this on 12th october. 90 days are coming to end on 18th , i returned. they wont fixed these issue.. rbk50 are more than 11 month since they playing with firmware..
- DarrenMJan 04, 2018Sr. NETGEAR Moderator
We have a beta firmware that has fixes for the 2.1.1 issues you can find it here.
https://community.netgear.com/t5/Orbi/OrbiOS-2-1-1/m-p/1476960#M19962
DarrenM
- atiq332Jan 04, 2018Star
i upgrade beta just to let you know first reaction. my wifi speeds are not crossing 100-113 and pind ae high too... can i get back to my first factory firmaware ? i think which is .74.. was very happy without any problem i get 300mb all around my home
- nXXoJan 04, 2018Apprentice
for me work better than 2.1.1.16
- atiq332Jan 06, 2018Star
did we upgrade to the latest beta firware? i dont wants to mess arnd my router any more plz adviced
- atiq332Jan 07, 2018Star
please can you tell me where should i upload latest beta firmware for my rbk50 set
- allroadusaJan 07, 2018Guide
https://community.netgear.com/t5/Orbi/OrbiOS-2-1-1/td-p/1476960
2.1.2.10 has been very stable so far.
