Jroach
Mar 14, 2018Luminary
attached devices shows devices that are physically wired as connected via wireless
Having issues with network "thrashing". General: I put in Orbi a few months back. Continuosly troubleshooting things that I can't quite figure out if I'm having multiple device issues or an Or...
Mar 14, 2018Guru - Experienced User
What FW version is the router system using?
Maybe something that will be changed in next FW update.
Jroach
Good question. I am on 2.1.2.18.
I have heard that this version is a BIG problem but I can't figure out how to go back to the previous version to see if my issue is related to firmware.
- JroachMar 14, 2018Luminary
I found the old version of Firmware.
Downloading now and will install/report back.
- FURRYe38Mar 14, 2018Guru - Experienced User
Well if this is just a display issue and the system is working otherwise, it's recommended to keep whats loaded.
However, let us know.
Downgraded the firmware per my previous post. For anybody reading this make certain you downgrade the satellite first. I didn't follow that step and it was a real pain to fix it.
So far the devices are showing up correctly.
