Xerical's avatar
Xerical
Initiate
Nov 10, 2017
Authentication Error Occurred
My wife and I both have Samsung S6.  Recently received an update to the phone and afterwards it no longer stays connected to Orbi.  My Orbi is on version 2.0.0.74.  I tried rolling back to 1.11.0.20 like some posts suggested but within a 60 seconds it auto-updates its firmware back to the latest.
Both phones says "Authenication Error Occurred" under the WiFi network.  If I turn off WiFi and back on it will reconnect.  But within 30-60 seconds it disconnects with the error again.
In addition to firmware I have factory reset the Orbi which didn't resolve the issue.
Thanks
  • Same issue with my S6.  Hoping this gets addressed before my 30 day return window closes.
    • bolingde's avatar
      bolingde
      Guide
      I wouldn't hold my breath, my believe is netgear will let people use the public network fix until the s6 disappear.
  • I just want to point out that this is definitely NOT just an issue with Samsung firmware. This is an issue caused by the Orbi router, firmware, and 5 ghz band. I have the same authentication issue on my LG G6 and Asus 3S 10 tablet. Both of these devices have connected and worked fine with other multi-band systems. But as soon as I got my Orbi in yesterday I have 3 devices that won't connect or stay connected to it at all. Even my Macbook Pro gives me an "invalid password" message even though the password is correct. All of these devices have not reported the same issues with other brands of routers. I don't feel like waiting around on Netgear to release a fix so I'm probably just going to return mine. I had high hopes for this system but it seems Netgear is in the middle of a firmware update fiasco and I got in at the wrong time.
    • As a few have already stated, if I hadn't already invest in my system I would probable look for another solution as well. The fact that is has not been fixed lead me to think Netgear just doesn't have either the staff or desirer or both to fix this problem.  I've worked around this issues but makes me think what if it wasn't a issue with a work around, you'd just be dead i the water for who knows how long waiting on a fix.
      • zoro25's avatar
        zoro25
        Running 1 RBK50 and 2 RBS50's with an Galaxy S6 Edge and also have the same issue,
        This makes the Orbi's unusable for me and the workarounds of unprotected network or only using 2.4Ghz also won't work.
        Can't believe this hasn't been fixed yet.
        Luckily I'm only about a week and a half into ownership, to me, it looks like a blacklist issue as my phone was working fine until I changed the SSID and not being blocked out, with the "fake error message"
        Authentication error occurred,
        Also, my satellites also disconnected as have all of my other devices over WIFI so only ethernet devices are currently working.
  • Mine has been working well for a few months on a S6 active. I can't even remember what I changed but I can tell you that it does work for some people.
