Daniel-UK's avatar
Daniel-UK
Apprentice
Dec 04, 2020
Automatic email when new firmware is released?
How can I get an automatic email sent when ANY new firmware for my Orbi is released?
The iPhone app or the web interface only show major firmware updates and while they show "No new firmware version available" from Orbi RBK53 | WiFi System | NETGEAR Support I can see that there is a newer version V2.7.1.60.
This is the ONLY email that I would like to receive from Netgear but I can't see how to subscribe to it!
  • FURRYe38's avatar
    Do you have a profile set up here?
    https://www.netgear.com/support/#
    v2.7 versions are for USA region only so anyone outside of this region would not be getting notifications regarding it.
    Contact a forum moderator for help with email notifications.
    • Daniel-UK's avatar
      Daniel-UK
      Apprentice
      Is it possible to get automated email notifications when a new firmware is released?
      Please answer either
      • YES and step-by-step instructions on HOW to get them
      • NO, it is not possible.. you have to manually check on the netgear website
      Thanks in advance
  • CrimpOn's avatar
    CrimpOn
    In the past, I would occasionally see a post mentioning "I got an email from Netgear about new firmware..." and would wonder, "why is this guy getting an email and I did not?"   Do not recall seeing one of these posts in at least a year.  In my case, I have NEVER received email announcing firmware updates for any of the Netgear products I registered.
    My conclusion is the answer is, "No.  There is no method to sign up to learn about firmware releases and only firmware releases."
    Fortunately, as long as the Orbi is functioning correctly, there is no urgency about updating firmware.  This is not a PC where hackers are discovering serious new vulnerabilities daily.
    • vajim's avatar
      vajim
      Master
      NG pushes FW updates to you when your system needs them.  Relax
      Daniel-UK
      Apprentice
      CrimpOn  thanks for your useful answer. So far I reached the same conclusion that the most useful email notification is not available!
      FURRYe38 sorry but your answer is not clear. Are you saying that you don't know if the answer is YES or NO but Blanca_O can help answering it?
      vajim unfortunately NG does not pushes all the updates but only the minor ones. The last 2 updates both contain security fixes and were not pushed. So there isn't much to relax.. or to rely on NG doing the right thing..
      • vajim's avatar
        vajim
        Master
        That's not what they told me.
        I don't do manual updates and my network has been fine for over a year.  If you do a search in here you'll see where folks that download the latest and greatest FW when it first comes out end up reverting back because it was not ready for release.
        You sound like you need the assurance of a newly released to make you feel good.  That's fine for it's your network and you can do as you please.
        Good luck
