Dream_Designer
Apr 02, 2020Aspirant
Backhaul showing 50% speed
Hello all, I am having 3 satellites and one router, my most far end satellite was not getting connected, so I decided to backhaul just one satellite , after speed test I found that it's showing 50% of the actual speed coming. from main orbi router R50 we are running on fiber 300 mbps
Please suggest what setting should i enable to bring the original speed to backhauled satellite
my second question is it alright to connect just one satellite or is it need to be connected to all by ethernet?
You can certainly do ethernet backhaul:
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-SystemWhat is the size of your home? Sq Ft?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).- Dream_DesignerAspirant
Thanks
Any Wifi Neighbors near by? If so, how many?@2.4 is Auto and 5ghz is 48 before I set to manual can you explain what does it mean and what is the meaning of unused channel?
Nearby around 8 wifi connections while sitting at home if i search for wifi it get to see 4 wifi names but I dont understand how is this going to effect us as they are not using our wifi
our house is Three floors 3500 sq ft each floor here is the map
top floor has main router and one satellite covering almost the complete area
medium floor = parking with 8 ft height has one satellite which is sufficient for that desired area
Basement = one satellite wired
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).from where I can disable these?
Today I tried to hardwire one of the. satellite to another satellite around 40 ft distance it was showing 10% of the speed
here is my backhaul connection map cat6
Internet - OrbiR50
R-50 - Sat 1 Distance - 50 ft Speed - 50% of actual ( 300 mbps fiber)
R-50- Sat 2 Distance 30 ft Speed - 100% of actual
Sat2- Sat 3 Distance 50 ft Speed - 10% of actual
Sat2 - sat 4 Dsitance 30 ft Speed 30% of actual
Am i. doing wrong connecting this way ? or. any setting which i need to check ?
