ThiagoFelix
Sep 25, 2020Aspirant
Backhaul Speed Check
Hello Everyone.
I am new to netgear communitty since I have just bought a Orbi 6 AX4200 (RBK752).
Setting up the mesh system was easy and everything was ready in a few minutes.
The connection between the sattelite and the router is showing GOOD on the status.
Netgear claims that the backhaul speed is 2400mbps, but I don't know where to check it. When I access the configuration page through the web browser and check the port statistics I have this:
Port: Status:
2.4G WLAN b/g/n/ax 573.5M
5G WLAN a/n/ac/x 1201M
WLAN Backhaul 1201M
Does this sounds about right?
I am not an expert but with this information I am guessing my backhaul speed is only 1201mbps.
Can someone help me to clarify this issue?
Best Regards.
Thiago
Orbi 6 RBK752 Firmware Version 3.2.16.6_1.4.4
- MstrbigMaster
If you look at the specs, there is an + next to it meaning up to or read exceptions, etc. So the backhaul speed connection depends on how far apart the satellite is from the router.
- ThiagoFelixAspirant
I see. So, to reach 2400mbps the sattelite has to be what? 1 foot away from the router?
Is there a way to check this backhaul speed?
- MstrbigMaster
ThiagoFelix wrote:I see. So, to reach 2400mbps the sattelite has to be what? 1 foot away from the router?
iPerf may show you your backhaul speed.
