Duncan9988
Jul 10, 2018Aspirant
Backhaul status “config sync”
I bought 2 additional satellites, setup was easy, all was fine and then my original satellite from the kit now shows as Amber in the iOS App and has a Backhaul Status of Config Sync. I have tried mult...
Jul 10, 2018Guru - Experienced User
Are the top led on each satellite after you set them up turn ON BLUE?
Router and satellites all using same version of FW?
Whats the distances between the satellites and router? 30 feet is a starting point minimum...
