ALNJ2017
Dec 25, 2017Star
Backhaul status orbi
What signal strengths correlate to backhaul status on the Orbi satellite ? My satellite shows poor but signal strength for devices at the Orbi location is -70 or better ? Running V2.1.1.16
- Dec 28, 2017
no just if you have a device connected to that satellite run a speed test on that device and see if you are getting the correct speeds.
DarrenM
DarrenM
Dec 28, 2017Sr. NETGEAR Moderator
Are you getting slower speeds from that satellite?
DarrenM
ALNJ2017
Dec 28, 2017Star
hard to tell if satellite connections are slower.
Devices in the area near the satellite will connect to eith the main Router (upstairs) or the satellite.
Is there a satellite speed test that I can run from the orbilogin portal ?
