ALNJ2017
Dec 25, 2017Star
Backhaul status orbi
What signal strengths correlate to backhaul status on the Orbi satellite ? My satellite shows poor but signal strength for devices at the Orbi location is -70 or better ? Running V2.1.1.16
- Dec 28, 2017
no just if you have a device connected to that satellite run a speed test on that device and see if you are getting the correct speeds.
DarrenM
DarrenM
Dec 28, 2017Sr. NETGEAR Moderator
Are you getting slower speeds from that satellite?
DarrenM
