Mestegall's avatar
Aug 03, 2017
Bandwidth monitoring by device
Hello all!
I was wondering if anyone has found out how to organize and/or prioritize bandwith by device for the ORBI system? I have found a way to enable QoS, but have not found a way to set the priority of which device(s) receive(s) the signal in a specific order. I'm having trouble keeping the wifi signal on my CPI camera connected.
Any advice would be appreciated.
Thanks!
  • Quality of Service router settings won't help your WiFi signal.  Can you move one of the Orbi units closer to the camera, or move the camera closer to the Orbis?
    • Mestegall's avatar
      Mestegall
      Star
      I have relocated it already so that it is literally 10' from the orbi satellite device. It's basically as close as I can get it.
      • st_shaw's avatar
        st_shaw
        Master
        Are you sure the camera is connecting to the closest Orbi?  You might need to reboot the camera to get it to connect to the strongest signal.
