RegDawg's avatar
RegDawg
Apprentice
Apr 19, 2018
Beam Forming and MU-MIMMO
I noticed these options unchecked along with "fast roaming" (I think thats it) in the UI. Should these be checked for better performance?
    There's no hard answer to that - it's more of a try-and-see for your environment.  Fast-roaming can cause issues for some clients (excessive roaming, disconnects).  Mu-MIMO requires client support, and there's a lot of clients that don't support it (and won't get any advantage).  The beamforming option you may or may not see a tangible benefit.
    Some have seen stability issues on the Orbi with them enabled.  Some have not.  I personally have them off, as I saw no appreciable benefits in my home.  If you feel adventurous, you can enable, and turn them back off if you see issues or don't see a benefit.
  • FURRYe38's avatar
    You'll have to test them out to best suit your needs. If you don't any or many MIMO supporting devices, then you can leave MIMO disabled.
    I have Beamforming enabled and all is working well with my devcies.
